I am rebuilding a 1972 SL350 engine and I have hit a road block that I cannot seem to get passed. I tore it all the way down and split the cases, but I didn't really do anything in the bottom end other than clean up 30 years worth of gunk. I replaced the cam chain with a one piece Tsubaki cam chain and the teflon 'slider-type' cam chain tensioner from Bore-Tech, but everything else in the top end is original. I'm following the Clymer's manual for my rebuild, and when I put my cam back in and tried to slide on the tach drive and the ign advance housing and they absolutely will not go on. The cam is too low - it's like the chain is too tight and does not have enough play to get the side housings on. The cam chain tensioner housing on the back of the cylinders was not installed, so it's not like it was adjusted too tight. I couldn't figure it out and I thought maybe the chain isn't sitting properly on the crankshaft side sprocket, so I tore it all the way back down and split the cases again, got everything back together and I'm having the same problem again. This is my first Honda twin rebuild so I'm not really sure how to proceed. The only thing I can think of is that maybe I'm not supposed to have the cam chain follower installed with the different style chain tensioner? I'm out of ideas... Anyone ever have a similar issue? What was the fix??
