small 2 stroke honda h100 cafe and suzuki gp
Re: small stoker honda h100 cafe
i picked up a two brannew rear wheels never been used with perfect spokes so just unlaced them just need a quick polish but look like new but after i got them found out that david sliver spaires sells spoke sets for about 20 quid >:( but at least ill have two wheel sets stock steel and trick alloy ones :)
i vote 1 gold.
Out of curiousity, whats the rim size? The hub looks uncannilly like that on my cb125, which has slightly messy rims/spokes/hubs...
hi rim size is 18.
i allso saw that the small cb hubs look the same was going to check it out but i picked up cheap wheel set to use the spokes hubs. so i never checked it out size wise. i did see that small cb spoke sets are on ebay for cheap i can give you the sizes of the hub and spokes if needed
Re: small stroker honda h100 cafe
just laced the rims and wish i went with gold now >:( ill see what i will do for the front and might unlace and do gold :)
got some better pics been loving this little cafe so easy to ride trying to get my knee down but the old tires are all over the place :( ill try and get some vids i have a little vid of me riding down the street thats about it ill try and get some of me trying to lean it over but when the camara comes out thats when bad stuff happens :) :D ;D
Haha - love the "electric tape" racing stripe ;D
That little bike has come up a treat. Well done ;)
This is a really cool bike. I love how light she looks. Are you just running pre-mix or do you have an oil tank hidden somewhere?
--Chris
just premix only i do that with most of my bikes i had an oil pump go on me befor :( not good :( least i no thats another part that cant fale :) and saves some space and weight but means i have to keep oil with me but i do have a spair 600 ml umber the seat just incase ;D
hi have picked up a new project a gp125 come with 3 motors all in bits , and lots of spairs . i was told that the guy i got it from was going to race it but never got a start on it :) . some good bits with it tho he got a disc front forks and wheel to replace the poor drum ,clubmans, ect . this is just like the honda h100 but i plan on doing this track style no lights i am making a start on the wheels first , got the brake plate cut out and will take as much of the hubs as i can and lace them up with new spokes . this is going to be a slow project as i am going to try and put a ktm 300 water cooled motor in it if not ill rebuild on of the motors
Nice one with the 300 retrofit idea! That'll be a weapon if the chassis holds out.
Bloody nice H100 too, really clean lines.
Cheers - boingk
got the front hub machined and polished took way to long. sorry crap web cam pic :-[ and i have my new spokes now. i dont no if i should stick with the crome rims or do them black :-\
is that an orginal hub that you took material out of or is that a new piece? either way its nuts.
its an orginal hub from a disc front end model . the hub and forks should of been a small drum brake model but the disc model works 10000 time better. i just got it machined took the hub flange down on a lath and put in the cutouts and put some speed holes in it as i saw it on a old race bike at a show and thort it looked trick :)
i just have to do the rear hub now thinking of removing the ribs on the middle cooling fins i think thay are ? has any one dune this befor do thay really cool the hub?
got the rear hub sorted removed the 4 ribs from the middle of the hub and gave it a quick polish. drilled somes holes and sorted the flanges just got to clean up the cuts and give it a buff
befor
