locOleoN
ok...As we all know, the biggest problem of using late model sport bike rearsets on our vintage bikes is the verticle motion that the brake pedal is designed to make when it is pressed
On a Gixxer sportbike the rear master cylinder plunger is mounted vertically. The "tab" on the back of the brake pedal, that the plunger is usually mounted at the 9:00 postion on most sport bikes.
Since most of our bikes use a rear drum, the motion that is needed to pull the rear brake arm is Horizontal.
In other words, the "tab" needs to be at the 12:00 postion on the brake pedal like on the Raask or Tarozzi rearsets:
The motion created by sportbike brake levers is Vertical, EXCEPT the 2003-2005 R6 rearsets
I solved this Verticle vs. Horizontal motion problem by simply adding an "eye" rod end to a stock clevis mount that comes with the MC:
to give me this piece:
