so i got this ol' cb350...
cgull
and the damn thing wont stay running! more specifically, it wont even start running long enough to stay running. but first my new friends (first post alert!; the first one always seems come when someone needs something) the back story.
i had (and still have, in pieces in a closet if anyone needs anything) 2 cb200s two years ago. i bought one for $100 when i was working down in west virginia and i bought one in akron, ohio, for $300. the hillbilly bike didnt have a title and was mostly a pile of rust held together by gummed up gas but the bike from akron actually had a title (which i lost, twice) and i rode it for a week, my first ever motorcycle experience with smiles ear to ear.
and then... i found this site, learned about cafe racers and promptly proceeded to take apart my decent running motorcycle with no title, cut the frame in a moment of fantastic ambition of great things to come, and scatter all the pieces everywhere, become overwhelmed, and lose interest. this is how i came to have two bikes in a closet. years drug by and i died a little inside every time i saw some lucky fella puttin around on an old honda until i decided enough was enough; i sold a traynor bass head, a little vox amp, my grestch and my stupid alesis micron, which made the stupidest noises ever and i hated. now with some money to burn i scoured craigslist looking for a cb350 with a ride from youngstown to charlotte to see my brother, by july, i told myself, the endgame. i found this bike for $600 in cleveland, bought it off some crazy hillbillies (i just noticed ive bought most of my bikes off of crazy hillbillies) and brought it on home!
i cleaned the carbs, the diaphragms were in good shape, the floats my be set incorrectly because i dont understand how to set them, 20mm from what? i bent the tang that closes the droppy down thingie, is that supposed to be straight? aside from that issue im confident that they are clean. i set the points as best i could, the one on the left is at .010, which is too small, i know, but the one on the right is at .016. i messed with these things forever and this was all i came up with to get the timing right. the timing is reallllllly close to being perfect. the second cylinder fires about one degree past its timing mark but im just looking to get this damn thing to idle. im using a cb200 tank that i kreemed so im sure that im getting good 93 octane gas with no crud in it. all fuel lines are new. spark plugs are new. valve slop is set. battery is charged. ive been kickstarting the shit out of it and about once an hour it will run for a minute, fully choked. if i touch the choke it dies, and if i touch the throttle it dies. please oh please help me!
pictures:
the day i brought it home
with the 200 tank, which looks kinda cool
whens the last time you saw one of these?
thanks in advance fellas!
Welcome to DTT man!
Ok..... here we go: don't bother with high octane. You'll find out that the bike actually runs better with the normal stuff.
You set the floats by measuring from the gasket SURFACE, not the gasket itself. The carbs have to be tilted at the correct angle (is it 15 degrees?).
And the timing has to be damn near perfect - try try try until it's there. It will make a world of difference.
Have you adjusted the valves and done a proper compression test? Keep at it, and you will get plenty of help on here as well!
i sort of adjusted the valves, my smallest feeler gauge is .006 so i really couldnt do much. i made it so i could barley slide it into the exhaust valves (spec'd at .005) and the gap was half the size of the gauge on the intake side (spec'd at .002). honestly i cant tell the difference between .006 and .002 with my eye, but what the hell i gave it a shot. ill get a smaller gauge set tuesday. i was surprised that the manual called for 95 octane!!! i didnt even know where to buy that besides a racetrack!!! i had 87 in all of my gas cans so i made a special trip. im glad to know that cheap stuff works just fine.
bonus if anyone can tell what kind of car is in the background...
Got me on the car......
If you rip apart a soda / beer can, the aluminum is around .003". It can be compressed (which is the problem) to about .002" - sounds great, right? Wrong. The aluminum can sheer apart too. And you don't want a little chunk of soda can hanging around your valves. So if you try it be very careful.
Or wait until you get a proper shim. Where are you at again? Akron area?
a ha! clever, ill try that tomorrow after the ol' memorial day picnic. nothin quite like family, greasy breakfast and football to say i love america. im in youngstown, which is not so far from akron at all.
the car is a 1970 spitfire powered by a cb200 frame, which it turns out doesnt work so well.
Sweet cage - you can't see it but I'm green with envy. But you would have to get a REALLY big sprocket for that cb200 rear! :D
Be sure to check the simple stuff too - fuel flow from the tank, corroded plug wires, fully charged battery, etc. As simple as an old bike might be to work on, sometimes it's the small things that can really screw with you.
Well, your valve gaps are off for sure. It makes a big difference on these bikes, it probably wouldnt lead to not being able to start but itd really depend on how far off that intake side is (they could be completely closed up and the valve slightly open). The timing should be close enough to get the bike running at least, if you could get it spot on thatd be way better.
Did you set the carbs back to factory? I cant tell from the pictures but are you running the airboxes? It kinda looks like youre not cus i think i can see a bit of the battery in the picture. Could be running overly lean which would lead to hard starting and not wanting to idle very well. Try cranking the pilots out 1/2 turn and the throttle stops 1/4 turn from the factory settings and see if that gets you anywhere?
*edit* i mean, turn the pilots 1/2 turn richer. Im pretty sure thats out on your bike but i could be wrong. Check to see if the manual mentions which way is leaner and which ways richer, if it doesnt say, you can check the breakdown diagrams for the carbs and see if its letting fuel by it or air by it. If it lets air by, turn it in, if it lets fuel by, turn it out.
i set them to factory specs, im pretty sure my a/f screw is supposed to be closed and then open 3/4 of a turn; i didnt mess with the throttle stops at all but they do move in perfect unison. ill set them today too, thanks for the tip on that. i am going to run airboxes. i have the carbs off and on so frequently that i just left them off; matter of fact i never tried to start it with them on. ill mount them up for the next right leg workout.
i also have another question, to add to all of my other questions. the top end was extremely loud when the bike was briefly running, since is sat for so long is it possible that my oilways are clogged? the bike has 2 qts of new 10 40 so im sure its not low on oil. could this typewriter sound be my rocker arms slappin the valves? pointing to more valve clearance issues. thanks again guys!
If your valves are out spec, they can be really "clicky". Also, if the motor doesn't run long enough, the oil might not have had a chance to work its way to the top end.
heres a pic of the mess as of ten minutes ago...
i went to sears after the picnic and bought a better gauge set and set the valves all to .002, the top end sounds much better now! i put on the air filters for the first time and i got it to start, after much much much kicking, and run for as long as i wanted to let it, which made me happy. what didnt make me happy was finding out that its only running on the right side cylinder... i checked the spark at the plug when i got it and both sides seemed good but ill check it again before i flip out, i know i have spark on both sides at the points. that is the side with the carburetor that pisses gas due to float issues. i may have to buckle down and buy a compression tester but im so scared about that being the problem that ill throw up if i find out i need new rings or something. otherwise it was a good day on the scoot. ALSO! it would only really run with the choke at 75% and it revved reeealllly slowly. on one cylinder.
running on only one cylinder it will rev really slow....youre probably only running on one cylinder because the carbs need to be cleaned. the left cylinder is prone to not firing due to fule because the bike leans that way on the kick stand so the fuel all drains to that carb and gunks it up. clean the carbs and try again
heres a new bit of news, im not getting spark on the left side and the spark on the right side looks weak. i called the local bike shop and the fella said that i would have about $25 in a new general purpose coil and plug ends. if it only costs 25 buks for ignition peace of mind im all for it. i have a new set of points coming in the mail as well. im going to wait untill they get here and then super spec everything. ill have a new coil new points set valves and set timing. my plugs have only been run on for 10 minutes so they should be fine too. i really hope all of this works, in my head it should run with all of that done. im going to go through the carbs once more as well. i want to get this bike running tip top before i cut it up so all of the tedious frustrating stuff is out of the way and i can do all the fun creative stuff knowing that it will fire right up when i bolt it back together!
i had low comp. on my left cylinder from a cross threaded spark plug (dumb last owner). it caused the left cylinder to not fire pretty often.
was there anything you could do to fix it or is that just a buy a new head kind of thing? since i decided im mostly waiting for parts to show up now i had a nice relaxing day just cleaning the ol gal up, i really cant wait to be up on two wheels!
Relax on the valve clearance issue,,,I've had the the locknut loosen and the valve slapping away at .040+ clearance,,,,,slappy and noisey ::),,your timing can be 15 degrees plus minus,,it will run,,,,,,if it's not running,it's because it's starving for fuel,,,,,I suspect your pilot jets are plugged solid,,,there located under those rubber plugs :o in the carb casting(s),,,,,,,and or your petcock is plugged,,,,,,good luck
