Soda Blasting Carbs!
Tristan
Ok, so I'd like to sodablast my carbs, but dont plan on disassembling them.
If I fully seal up the intake and output on the carbs, do I need to worry about any baking soda getting in there? I assume those are the only ways in..but can't hurt to ask.
I just want to dress them up and get all that grease and peeling clearcoat off the body.
Yes, it will still find it's way in there somehow.
You can still blast them, but afterwards pull the slides out, pull the floats and bowls, and anything else you feel comfortable removing. Then rinse and soak in warm water a few times to get the remaining soda out.
^what he said. not sure what carbs you have but my vm29's have choke plungers that would sure let in soda media.
What kind of carbs? Taking carbs apart is pretty simple, depending of course if we're talking about a single Mikuni VM or a bank of 4 Keihin's linked together.
soda is water soluble. just make sure you wash your carbs off good afterwards and you should be fine...
If you have a clear workspace, and lay the parts down carefully together, you should be able to put it all back together in reverse order. Really not that difficult, I did it myself once I saw a buddy do one.
Then you end up with water in your carbs :o
Pull them apart and do it properly.
Yup, pull 'em apart, don't be a weener. My secret is using a muffin tin to keep everything straight. A six-up pan is good for twin carbs, 12-up for a rack of 4. One hole for slide stuff, one hole for external stuff (plugs, linkages) and the last hole for stuff from the bowl.
I used to mess around with an old dirtbike carb, trying to take it apart and reassemble it blindfolded like I was stripping a rifle. Then I got a girlfriend.
lmfaooo
did you ever do it perfect?
Oops! Lol, I meant "parts" not "carbs"...I read the OP to fast, thought the carbs were in parts already... :P
