soldering
Properly soldered joins are far better for conductivity than crimped joins - especially over time. I've lost count of the amount of arc'd / burnt out / fubar'd crimp and spade connectors I've replaced on reg/rec units over the years.
Crimping is far easier / quicker / more convenient to do though - and that's why you'll see crimped connections in wiring harnesses as opposed to soldered because it's far easier to do this in a production line environment.
Still, its the same as anything - whilst a good solder join is superior, a bad one is going to fail just as fast as anything else.
I've had countless issues with crimped connections on harnesses, especially on dirt bikes. Since I began soldering the connections, the problems went away. I've never had an issue with a soldered connection cracking or breaking since the solder fills the space in-between the strands of copper. Done well, soldering is the way to go. It just takes much more time to do.
IMO done properly either will be fine for bike. a My only caveat is the done properly bit, to do that you should pick up a decent crimper or soldering iron. If you crimp with a set of needle nose pliers or solder with a lighter you are asking for trouble.
