I have an electronic ignition system(known as a 'HondaMan ignition' over on forums.sohc4.net)that will use your ign. points as electric 'triggers' only so the points and timing/gap settings will last(no more burnt points 8)) Much longer.The system also gives a hotter spark w/ quicker advance curve starting at low speeds on up.I used it on my CB350 for 200 miles and removed it before selling my bike.
The system comes with full instructions and color coded wiring & extra solderless connectors.
This system will work w/ all dual points motorcycles and will handle coils down to 3 ohms.
The stock points and condensers will still be installed and your cam chain should be in good condition for this electronic ignition to function at peak efficiency.
$65 shipped to the lower 48
