After taking a break from bikes for a bit to get the race car ready for the season, I got back into it full steam ahead. I picked this up from a local member with a title for 400. It's a 76 cb360 and the motor is from a 73 CB350. After checking everything over in the motor, it is apparent it was rebuilt as the gaskets were all new and the pistons/cyl walls are like new with honing marks. I blasted the frame/swingarm and various engine covers myself before painting/powdercoating. I had the frame/swingarm done in wrinkle black locally for 125.
Here is the bike as it sits today. I decided on the cb500t tank as the look/size is perfect in my eyes for this build.
I decided on a flush mount pop up tank cap. I cut the stock cap off and fab'd a piece of steel to fill it in. Needs some bodywork after the bung is fully welded in.
I had a buddy drill the rotor since he has a nice size drill press. He tapped all the holes with a countersink bit to clean up all the burs. I need to clean it up and repaint the center part.
Also decided to run roccity clipons for this build. Awesome quality!
I chopped up the front fender and decided to use my dimple die on it since it was a touch thinner than 16gauge steel. Worked great and added some extra rigidity and racey look
More updates coming tomorrow afternoon with some bodywork on the tank filling in badge mounts and some dents. Also plan to mount up the forks/headlight brackets/clipons. Thanks and take care guys!
Jared
Jared
