SPARK PLUGS. CB750
killerdwarf
A couple of years ago I pulled the plugs out of my engine, and have seemed to misplace them. I never really had the desire to start the bike before...until today. I found 3 plugs laying around in various spots which happened to fit my engine. All 3 are different. The motor fired up on the 3 plugs!!! Now I need to know which are the proper plugs for it so I can get 'er running right 8) Which plugs do I need to get? Thanks
CB750F:
NGK Standard - NGK D8EA
NGK Iridium - NGK DR8EIX
CHAMPION: Champion Traditional spark plug - RA8HC
killerdwarf said:
Thanks! Now that that is done, what should the air screws be set at? I have them at 1 turn out right now.
Thanks depends on the bike and how "synced" your carbs are to the motor...
The standard settings are in the manual..
I believe its 1.25 revolutions from fully closed...(therefore turn it all the way in till its stipped then then count 5 quarter revolutions on each carb)...but DONT quote me on that...
killerdwarf said:
OK thanks, and while I have you on the phone Leon what should my valve clearances be set at?
Now that I honestly dont know... ???
I"ll have to check the manual...
Because I didn't know there was one, because it's quicker, and easier just to tell me, because I'm on dial up, and at 31.2 kps it would take me about a month to download :o If you could be so kind as to hook me up with a link to the manual, then I could forward it to the wife at work and have her print it for me 8)
