Sparking inconsistently on one cylinder and only at high rpms?
jh321
Active Member
I have a '73 cb450 that I pulled out the back of a barn. It starts up but only runs on one cylinder. The weird part is that it will fire on the left cylinder if the rpms get to around 4000 and the spark is inconsistent.
I have spark on the left side but not consistently at all. I have cleaned the points, and arching across them only fires the spark plug every 4th or 5th time. Using a volt meter I tested the points to spark plug wire cap voltage and it read off the meter when the points were opened (ie correct high voltage). Yes, it does have brand new plugs in it.
I'm lost...
Any thoughts on this?
What about the condensor? did you try swapping from one side to the other, also try the same with the coils.
