Spec sizing for CB350 pistons
danfr
I'm getting my cylinders bored and honed. i have a .5mm over piston and rings coming but cannot find the specs for .5 over. any help or direction would be appreciated.
Here's the straight poop.
The machine shop you're having the boring/honing done at should be insisting on having the new pistons IN HAND before doing the work.
Every piston is manufactured within tight tolerances, but there ARE differences from one piston to the next. The machine shop (who should do motorcycle work regularly) should want to measure each piston, assign it to a cylinder, label the piston, and then bore the cylinder to match that particular piston, with clearances they decide are appropriate based on whether you're racing the bike or street riding (or to the specifications in the user manual - they are in there).
You should NOT machine the cylinders before you have the pistons in hand. You should be paying about $50 a hole for boring/honing.
clearance spec is in manual but, as Tim says, you need the pistons to finish cylinder.
You can usually bore to within 0.08~ 0.10mm then hone to finished size (about 0.002"~0.004" honing allowance, depending on finish 'off the bar')
Modern CNC pistons are made with correct undersize for 'full' bore size (i.e. a bore of 56.50mm will have a 56.48mm piston)
It's still wise to check before finishing.
PJ
the pistons are NOS 0.5mm over. I'll bring the pistons and rings in to the machine shop with the spec printout from the honda service manual. i'm sure they don't appreciate customers telling them how to do their job as i don't appreciate customers telling me how to do mine. They machine shop sounds pretty trustworthy from a couple online reviews and i have faith that they know what's what. i may end up getting them to piece the whole top end back together.
thanks for the help. much appreciated!
I think Honda say tighter than that, 0.0008"~0.0012", don't remember where I got that from though.
I only use 0.0015~0.0017" on 2mm~14mm overbore motors ;D
PJ
