jacksondee
Active Member
ABOM said:It did? NICE! Did you have a separate negative (-) to each cable(+), or as I, like only 3 or 4 (-) for all the (+)?
Asking since I still have a problem with the lights...
I believe that I have the problem since there are not enough negatives (-) and I guess I've fixed them at the wrong place..
I believe everything in the speedo had one positive and one negative. The problem was the separate left and right positive wires that the bike had. So like the fellas said, I wired the one negative wire in the new speedo to the ground that the oil light and neutral light went too, then wired the two separate left and right turn signal wires to the diodes. Then the diodes tothe one positive wire the new speedo had. In your picture from earlier posts, it looks like you've set it up properly.
I think the guy was right earlier. I've read that if you've replaced your stock turn signals with LEDs, then you have to add a resistor in there or something to get the proper amount to go through the stock flasher relay. I guess in other words, to make them actually flash. The old bikes arent set up for LED flashers and need a minor upgrade in the form of another piece wired in there, just like we had to do with the diodes already.
I thought I had the image of the original wiring diagram that came with the new speedo on my computer, but apparently I do not. I have a few hours of work to do but can post it later if that would help you.
