Spraycan Frustrations
Herbonius
I've been trying to paint my bump stop seat for the past two weeks and it's driving me crazy. I have a good, clean environment to spray in and I prepare the surface well but every time I spray, the spraycan inevitably sputters at least once, spoiling the coat. I then need to wait 48 hours for it to cure before I can sand out the offending paint drops and do another coat -- where it will inevitably sputter again, wasting another two days.
Has anyone got any tips to stop this from happening? I clean the nozzle before and after spraying, I'm spraying horizontally from about one foot away and I'm doing dusting coats rather than putting the paint too heavily. Aside from the areas where the can sputters, the paint looks great. These drops on the paint completely spoil it though.
I just have a few questions. What is the temperature of the room and surface that you are attempting to paint? Do you have another spray can tip that you can try on this can? Did you try the trick of putting the can in a bucket of hot water for a few minutes then shaking for a few minutes afterwords before applying paint? . Are you shaking the can in the middle of each coats or every 3 or so Minutes . Maybe trying a new can of that paint. Before ruining your paint job again and having to sand it down again I would test it on cardboard to make sure the can is working properly.
Spray bombing is hard, it rarely irks out perfectly.
Try this, let it dry, wet sand the whole thing, clear coat it, thre clear will bring out that pretty color, and you can sand and polish the clear if you have imperfections.
The first couple coats can be light coats, but if you want the paint to flow out smooth, the last coat has to be pretty wet. Best paint flow is just a RCH shy of being wet enough to run.
I do plenty of fine paint work with rattle cans. It ain't the rattle can, it's the painter. You have to learn to lay more paint on. You have to have good lighting, warm temperatures, and a clean environment.
Just another note when you're spraying don't let the can run completely empty you want to discard it before it gets to the completely empty stage. once it gets close to empty it will sputter.
+1 to this. clearing it after a light sanding will make it look bright and shiny again.
Paint is pigment in a solvent like chemical. When its warmed it "thins" the paint allowing it to atomize more efficiently. Allows for better flow, smoother coats, and most importantly a more consistent performance.
