the naybor who is out of work been helping here at the shop,(major spring cleanout) (yes i pay)got a cb450 wants to get it on the road
normaly i say NO i never work on others bikes
but i caved then i did all the things you would do with an unknown before startup adjust cam chain inspect adjust valves it has good compression
so i told him lets make sure the thing has a chance ,i wasn't seeing any oil up top,i had the guy clean the spinner it was not bad at all
spun with 12 volts plugs out ,dry up top :-[
spun with 24 volts plugs out ,dry up top
there is oil at the filter cover,its got its 2 orings,oil ports are lined up,spring-loaded oil transfer deal is good ,oil is full on dipstik
so its got to be a stuck check ball in pump or plugged screen or pump stroke eccentric worn badly resulting in a short stroke ,pretty common on the 350's,.or all the above
am i missing anything ? any suggestions are welcome even if your gonna tell how stupid i am, have at it
fucking never again
now i am stuck in the middle of my shop cleanout with a dodo in the way
i tried to tell 'im its a parts bike when he first rolled it in ,tole 'im its gonna take a 1000 dollers to get it road worthy if yer real lucky
but but but
fucking never again
but but but
