squid compression question
raptormeat
i have 150 psi in both cylinders on a 360 standard is 170psi.
is this why the bike wont go above 60 or is it something else entirely, probably jetting?
basically im wondering if cylinder compression affects top speed as well as acceleration or just acceleration.
Something else entirely. Nothing wrong with 150psi. If it was 100 then you'd be looking to rebuild.
Start with valve adjustment, timing, fresh plugs, and then move on to syncronizing your carbs / worrying about jetting.
You're also not a "squid" or any other douchey name arrogant pricks call folks who are still learning.
Nobody's born with all the answers.
Anyhow, as stated, your compression is good enough. How's the timing? What do the plugs look like? Have you done any modifications that would require rejetting?
It's probably splitting hairs, but while your compression is "good enough", it isn't great. This assumes those are warm compression numbers though. If that was a cold measurement you're probably just fine.
Have you made any changes to the bike or is it stock?
static timings good, need to check advance tho. have cm450 mufflers on it, stock airbox and also am at 5000ft elevation so i know its running rich. have bought apparently 2 wrong sets of main jets so far. cant seem to find the right ones for the 360. if anyone knows let me know! i have the 76 which has 754A keihins. might try to raise the float level to 19.5mm? will report back!
Compression is "OK." It might be better if you prop open the carb slides when you do the compression test. The carb slides being closed can make your reading slightly less than what it actually is.
Make sure your ignition advance is working.
Those compression numbers are fine for 5000 ft above sea level. Also, it's very rare to need to replace the primary main jets on the Honda 360 carbs. You'll want to be changing out the secondary mains. Check out Jets R Us. I'd start with 110s and go from there.
