SR250 engine swap
turdie
Hi all, does anyone know if the XT250 or TT250 engine will mount straight on to the sr250 frame without any modifications
I am still learning whilst attempting to restore an sr250
The way i think it, is if i can swap in an engine with a kickstart, it will save much time and effort, finding and wiring all
the electrical compnents, which isn't all present.
Much help appreciated, thanks
Pretty sure I remember reading on this board that you can retro-fit an XT kicker onto an SR motor. So, I'd say the engines would be identical (crankcase wise) and should fit readily into the SR frame.
Worst case scenario is if you buy an XT motor and it doesn't fit, you can at least put the kicker onto the SR motor ;)
never tried it but if you either swap generator or wiring/ignition and it should be fine
PJ
I don't see why it wouldn't fit. I used the kickstart parts off a TT250 to add a kickstart to my SR250 2 winters ago. All the parts should be interchangable other than the electical system. There's a good chance the XT and TT250s are 6V instead of 12V. At least it was that way with my buddies XT5000 vs the SR500.
ahhh, that's great, thanks guys
i'll be in search for a candidate for my transplant,
also, will be replacing the electricals, due to sorry state of the existing ones, they are beyond recognition
will update my project, when it's under way
cheers
Turdie
