1
1971G3SS
Guest
Not sure what's going on. I recently installed a new mini LED speedo from dime city cycles with the signals, high beam, and other indicators. I also have the antigravity battery. Now this is where I'm stuck.. I have the clutch cable on and I go to install it to the clutch perch on the handlebars and it sparks and begins to power the starting motor. It does this whenever I touch the metal end of the clutch cable to any metal on the bike. The cable is on the engine. I know this may be confusing. Also my neutral light stays on even when I have the ignition key turned to off. Do I have the lead wire from the starting motor connected to the wrong spot on the battery? I have it on the positive lead on the battery.
