SR500 Piston Size
foundation982
I bought this SR500 yesterday and the Piston smacked the valves and I'm going to rebuild it but just now measured the piston and its not a standard size. Its 3.546 inches or 90.0648 mm.
Just wondering if a 3mm over would fit correctly or if anyone has any input that would be great! :D
Photo0181.jpg by foundation982, on Flickr
That's a big change - what is stock compression? I'm just considering my SR500's engine. You should check out Thumperstuff.com - great guy and knows everything (and has lots of different pistons).
9.1 is stock but there's people putting up to 100mm pistons in em.
I've been on that website its all awesome stuff but a bit pricey
The bore of the piston doesn't change the compression - that's dependent on how much space is left in the head at the top of the compression stroke, which is based on the design of the piston.
Putting a 100mm piston in will just increase the displacement, not the compression (unless it's a high-compression piston).
