SR500 White Bros/Supertrapp exhaust
bcthomas
This is complete and sounds awesome. It has some patina and small dings/scratches/bluing as seen in the photos but is in good condition for a rider.
$150 shipped in the lower 48. I will ship anywhere else for actual cost. I am in NW Arkansas.
Can you give me the od and lenght of the pipe gasket surface to the weld at the muffler
The pipe OD is 174mm and steps up to to 189mm at the flange where it mates up to the head. Total length of the headpipe from the flange to the slip joint at the muffler is 32"
The muffler is 17" from the slip joint to the discs
Installed on my SR
hillsy said:
You might want to change the battery in your verniers.....
Ha...yes, or remember to use deciamal points and remember that I'm not using the metric system.
1.17" and 1.89" respectively.
hunterkey said:
what carb/jetting were you running with this? oh and what airfilter?
A large K&N with a 36mm mikuni from Thumperstuff. I haven't changed the jets so whatever Mark puts in them for a baseline.
so are you selling the mikuni since the pipe is sold? ;)
I have been thinking about going that rout with mine eventually. I just want to retain the stock look.
Super pumped to see what the pipe does for me!
Thanks Again
