Stainless Bolt Kits
Redline
Bullit Custom Cycles unpolished stainless fastener kits for your vintage motorcycle are available! The kits are sorted, labeled and include instructions. They're not just a random assortment of bolts! These are perfect for your basket case, restoration or what have you. These kits are all Allen socket for ease of use and specifically designed to fit the models listed below!
1969 - 1979 CB750 SOHC...$29.99
kit includes:
Valve Cover - 20 Socket Allen
Tach Drive - 1 Socket Allen
Stator Cover - 8 Socket Allen
Outer Stator Cover - 3 Socket Allen
Left Rear Covers - 11 Socket Allen
Clutch Cover - 10 Socket Allen
Clutch Outer - 3 Oval
Ignition Cover- 2 Oval
HONDA CB550 / CB500 4 cylinder...$29.99
kit includes:
A:LEFT FRONT COVER 4 pieces
B:KICKER PINCH 1 piece
C:SHIFTER PINCH 1 piece
D:INTAKE 16 pieces
E:STARTER COVER 4 pieces
F:SPROCKET/CHAIN COVER 4 pieces
G:EXHAUST 16 pieces
H:RIGHT COVER 12 pieces
I:CYLINDER HEAD 33 pieces
HONDA CB450/CB500T...$29.99
kit includes:
a:intake 4 pieces
b:exhaust 16 pieces
c:cylinder head covers 24 pieces
d:left crankcase cover 15 pieces
e:points/tach cover 11 pieces
f:right crankcase cover 13 pieces
g: camchain adjuster cover 8 pieces
92 pieces total
HONDA CB350 CL350 SL350 CB250 two cylinder 1968-1975...$32.99
kit includes:
A:points and tach cover
3 oval phillips screws
B:cylinder head cover
5 socket allen screws
8 acorn nuts
11 washers
C:intake and cylinder head
8 socket allen screws
4 washers
D:left side cover
10 socket allen screws
3 oval phillips
9 washers
E:right side cover
F:cam chain adjuster
4 socket allen screws
G:starter
2 socket allen screws
80 pieces total
Yamaha RD250/350/DS7 and R5...$24.99
kit includes:
A:oil pump cover
B:right crankcase cover
C:left crankcase cover
D:clutch adjuster cover
E:generator cover
F:reed valve
G:exhaust
35 pieces
Yamaha RD400...$24.99
kit includes:
A:RIGHT COVER
B:OILER COVER
C:LEFT SIDE COVER
D:POINTS COVER
E:CLUTCH ADJUSTMENT COVER
F:KICKER PINCH
G:SHIFTER PINCH
H:INTAKE
I:EXHAUST
35 TOTAL PIECES
Re: Re: Stainless Bolt Kits
Doppio said:
Do you have any for a CB360?
Looks like the listing for the CB 350 might have the correct number of fasteners. But I would want a confirmation of that before I ordered.
phat fingered on my phone with Tapatalk
if not there is a seller on ebay that has em. only problem with stainless steel fasteners is stainless tends to "stretch" especially when torquing down valve cover bolts, so be careful and use loctite or antiseize depending on the application. or you migh strip some threads
veloracermike said:
Any one heard from these guys? Paypal'd them a while back and nothing.
Yah Mike you just contacted us 4 hours ago! Give us a chance to respond when you send an message!!!
