Staring down my cl360
XsjadoTwin
Okay I've come to a cross roads in my build. She is running, just ordered some fresh rubber to replace the 25+ year old dry rotted tires. While the wheels are off I'm going to replace the bearings, copper/bronze/brass plate my spokes/rim/drum brake (in that order and in those coreographed metals) ...
But while staring down my tank and mocked up cowl I came to a symmetrical Epiphany: what if I were to mount the gas tank backwards to give the flow of the tank/frame/cowl a more arc'd symmetrical profile....
Anyone ever seen this done before? I imagine I could pull it off, but ideally I would like to have 2 of the same tanks to ensure a nice consistent body line from front to rear. One to act as my fuel tank, the other to cut up and use as my rear cowl. (I could either make a fiberglass mold of the chopped tank to save some weight, or use the tank itself and continue on with my "bare metal" build theme)
Opinions?
Follow up question... What is a mid/high volume tank that wouldn't look TOO awkward on a cl360? I don't mind a little metal work or modification (how ever I would like to stay away from altering the main fuel bladder) making and welding tabs/mounts to fit to the frame is not an issue, I have the resources and neighborhood gang who are more than willing to lend a hand....
I'm trying for a little more unorthodox original look and to stick to a rounder, curvier cafe style, while having the larger capacity tank than the stock ~2.75gal the cl360 tank gives me... Ambitious? Yes. Will itlook right? Who knows. I'm just trying ton think outside the box here :)
how about a photoshop of your bike w a backwards tank. I can't even imagine what that might look like.
are you thinking just setting the tank on there. w the floor of the tank running up hill towards bars? and sitting on top of frame nearest the triple, so the coils are exposed. because the taper of the tunnel would now be sitting above the frame at the triple.
or
Modifying the tank tunnel so the floor of the tank sits level down over the frame and coils, leaving a big gap nearest the seat?
