Friends,
After fully dismantling my cb350k4 (1972), and changing/cleanings some bits, I successfully reassembled it and it fired up first time ;D. However, after a bit, it started to idle very high, around 3,000 rpm :-\. after a few adjustments with the carbs including the throttle cable, air screw and stop screw, the bike would either idle very high with the choke open, or stall out, especially with the choke closing. The bike then sporadically stopped starting. It grinds as though it is trying and starts to turn over, but won't turn over. There is no fuel overflow from the carbs or anything.
I just can't get the carbs adjusted to correctly idle the bike. Any recommendations? Any recommendations on using the choke?
Any thoughts on why it won't start now, but did a few times ago? Could it be a sparking problem or something? I'm new to this, so please be gentle. Thanks ALL! :-\
