Started to think "tuning" problems are "electrical"
MB
Coast to Coast
So the bike was running sweet as a nut. But after high revs it does the stagger, which I spent a while chasing my tail around as a fuel issue. Problem is it kicks back up after dying when it does. It recovers from the stagger after a short while below 4000. It also runs great at high revs. If I'm just stop start riding around BK, no problems at all. Idle it's constant throughout all this too. So I put the battery on the meter:
Off the battery is at 12.65
Switch on 12.25 w lights, horn bumps it up
At 2000rpm it's at 13 and above, fluctuating
At 3000rpm it drops dramatically
From 4000rpm to 7000rpm it drops frantically and is unstable, it'll go as low as 4V, will fluctuate up to 9V but will not push past 10V in its ups and downs
One it returns to idle it is very strong up to 13.5-14.5 then drops back down if the bike doesn't cut out beforehand.
I just rode arountheir 30 minutes and the idle stays true, the bike feels good till 4 or 5krpm (guessing, no tach on bike) and doesn't have any trouble till AFTER I have hit a stretch at high high revs. It'll do the stagger again for a while but seems to recover, unlike a warm bike with fuel, jetting problems.
Diagnosis help needed electrical is no strength of mine
1971 350
That sounds like a vibration short. Check all the connections in your charging system, MAKE sure the bolts are TIGHT at the battery, and check to make sure the ground to the engine is CLEAN and tight. I would also check your fuse connections as well.
It should sit at idle lights off at 12.5-13.5 and be at 14.5 or better from high idle all the way to red line. IF it runs higher than that you have a bad regulator, hell the regulator might be bad as is and so might the rectifier.
At this point I am worried about the wiring being incorrect. My buddy and I required it according to an educated guess. It ran up to 15 but no higher and was stable across the board high and low. But then the bike ran like shit. Worse. Wondering if the tune isn't right for a different spark scenario
