Started XS650 project
magnang
Just getting started on my second cafe, I had been on the lookout for an XS650 for a while... I was looking for a standard but they are rare. Wound up getting this '81 special to cafe. The stance and esthethics aren't as great, but this one has full compression, frame is straight, and it has a few nice to haves like electronic ignition and the Mikuni carbs that are rejettable.
It's f***in ugly though!!!
My plans are to take it down to the bare frame, strip off all the old paint and rust, paint the frame black. I will get shocks to raise the rear end a bit, a nicer tank to get painted British racing green, a cafe seat ( I may make one from the stock seat), reverse cone mufflers or a 2 into 1 (budget permitting)... Budget permitting I wouldn't mind mesh wheels either. The cast wheels are ugly but they have good tires on. I may just paint them black or gun metal.
Makes my CB175 look like a toy though...
Great starting point.. Just expect to have some charging problems!!...
I'm looking forward to seeing how this one turns out. I really like the look of these bikes. I'm going to look for one as my next project.
jay
jay
I'll keep this thread updated, but the progress is probably going to be slow!!! I have about 3-4 hours a week to mess around with it. This is going to take all winter.
Does anyone have a good recommendation for a nicer tank I could swap in from another bike?
Wilcox alloy tank...
Oil in frame Triumph tanks will fit with some small fabrication work, or get a new reproduction tank from Mike's XS and yes the XS roadster tank will fit the Special frame mounts.
Terry
J'ville, Fl.
Terry
J'ville, Fl.
Will other Yamaha tanks fit? XS750, Seca ect?
Within the same platform you should be ok eg: 650 std vs. 650 Special
Chances are that outside the platform family you're SOL. I cna say for certain that the mounts need changing to run a 750/850 tank, I have both tanks and looked when I got my 650. However.......working up the mounts are generally pretty simple. If you can seriously contemplate building a bike like this then you more than likely can make your mounts for a different one.
Ok thanks for all the info.
Since I am going to need to fabricate something to fit a longer gas tank, I'm going to get whatever is available. I know a guy with a barn full of old gas tanks, so I'll just see what he's got. XS750, XV920R and GS450 tanks seem to make a good cafe setup. Some of the CX500 tanks look nice too. Once I have the tank and mounts figured out I will cut my stock seat to fit, lenghtwise and also a bit of width wise... the stock special seat looks HUGE! If that works out it will free up some money for a few more goodies. If not I guess I'll buy a cafe seat online somewhere
I haven't done too much yet, still very much in the planning phase. My budget for this is very small... Basically what I paid for the bike + what I get from selling my CB175 (let's say around 1000$).
I charged the battery I got with it, hooked it up... Turn on the ignition... Nothing. No lights, no horn, no starter... The fuses are good so either my battery is messed up or the wiring is fucked. Weird. Oh well, I'll have to take it all off anyways
I've been looking through mikes XS to try and figure out what will get me the most bang for the buck... Looking at getting:
- Mike's 2 into 1 exhaust with 18" reverse cone. My downpipes look bad and I don't like the angle of the special mufflers. More room for rearsets too.
- VM34 rebuild kits... My carbs look like shit. While I was moving them around they leaked what looked like fermented gas... Smelled like whiskey!!!
- Mike's pod filters for the VM34s, along with the jets he suggests: Main jet 142.5 - 147.5, Pilot Jet #45, Air Jets of # 127.5
- A set of progressive shocks either 324mm or 335mm to raise the back a bit, and bronze swingarm bushings. I'll also change the fork oil to 20W.
- Iridium plugs and new sparkplug caps... For starters.
- Stainless steel brake line for the front, for better feel and added bling bling. Will probably keep the stocker in the back, it works well enough.
- Wide center clubman bar. I will cut it to fit
Lighting wise... I'll keep the stock headlight and guages to save money. I don't like the taillight but will keep it for now. The turn signals will be swapped for smaller, lower profile units.
Rearsets... I have a set of FZR600 pegs and Ninja 500R rearsets kicking around. I might give this a shot too:
http://650wiki.org/index.php/12.02._Cafe_Racer_Idea
The engine is completely free of oil stains and has good compression. I will get a tester to see what the true numbers are, but it doesn't look like it needs a rebuild. The gears also shift smoothly, including neutral! It only has 14000KM on it. I will pull it out of the frame, clean it up and paint it black with engine paint. I will polish the "points covers" (dont have points but the covers still there!), valve covers and alternator / oil filter covers for contrast. While the engine is out I will adjust the valves. Probably get a stainless allen fasteners kit.
This is sort of the tank / seat setup I am looking for. That's an XS750 tank
Any advice on the plan? Is there anything I am overlooking or that I should look at getting? Anything I should replace proactively? I planned on doing a whole lot more but I want to have a few bucks on hand do deal with the unknowns...
looking good. here is the current state of my xs650.
i got a cafe seat coming from omarsdtr. that should be it and my bike will be complete.
I recommend staying away from the air filter pods. the stock airboxes work very well, and with the pods it's a PITA to tune the carbs. steering bearings are a mush as well as the bronze swing arm bushings. your also going to need a new pivot shaft and grease seals for the swing arm.. whatever your budget is add another 500$ cause you will run into unexpected issues. here is a great forum for the xs650
www.xs-650garage.com
p.s... mikesxs will be your new best friend
Your XS looks awesome. I assume you started with a late 70s standard? That's the bike I had an eye out for for the last 6 months but seems people here really like their choppers... All the ones I seen were specials.
Is that the stock 650 standard tank? Looks like you have a 2 into 1 exhaust as well. Doesn't look like the mikesxs one...
Anyways for me I don't have air filter right now, the bike didn't come with the stockers. As well my side covers look like crap, actually even if they were good the special covers are different and the look didn't really age well... I think I will give the pods a try, they are cheap, and I can get some help setting the carbs up. I'm actually keeping a few dollars aside to bring the bike to a pro at the end of the build. Something I wish I had done last time honnestly. Get it as good as I can and then get a pro to dial it in for me and look over any gremlins I will have left.
my bike is a 75. (standard) When I got it I had every intention of hardtailing the frame and doing a bobber build. when I brought the bike home i didn't have it in me to cut the frame. the tank is stock with a fresh paint job, the frame and everyrthing else has been powdercoated. I do have a 2-1 exhaust. it's an old MAC setup. hopefully my bike will be done in about a week or so. I'm thinking of relocating the battery and getting rid of the side covers and battery box.
if you have any questions about your xs just shoot me a line. I took my bike all the way down to the frame so I'm pretty familar with everything.
[/quote]
I have one of these on my bike and for the money I don't think that you can find a nicer tank. They are rust and dent free so no body work or tank coating is required. He carries the cap and the petcocks aswell. Mounting was a simple affair. A single bolt going through the tank into the back bone of the frame. I then welded a nut to the back bone for the allen head bolt to go through.........put some copper pipe insulation on the back bone to dampen the vibes, tighten up the bolt moderately, and I was good to go!
http://www.vintagecosmo.com/store/product_info.php?cPath=43&products_id=89&osCsid=0cf4e0b6239c3c93e28e918ab30aacf5
And here it is on my bike:
http://www.youtube.com/watch?v=tvtv3Nr9oxE
Dave
Very good sound man, i love it !!!
Friendly from Belgium, infrapista ;) ;) ;)
Dave
Dave
Very cool.. What rear rim and tire are you running there?
<a href="http://www.youtube.com/v/tvtv3Nr9oxE&rel=1" target="_blank">http://www.youtube.com/v/tvtv3Nr9oxE&rel=1</a>
Dave
Tank looks great and that's a good price too. Only issue I have with it is the colour... Seems theses come in yellow or orange only. Looks great on yours, but I had a yellow SV before and got sick of the yellow pretty quick...
Well after some thinking and looking at the standard vs special difference, and making a list of all the things I am going to do to un-chopperize the bike, I figured it will be easier and also much cheaper to just build a rat-rod out of the bike.
That way I can keep my headers (and wrap them), leave the rear end as is (minus bushings), keep the 16" rear wheel, special tank, side covers ect...
This sweet SR500 on youtube kind of changed my mind...
http://www.youtube.com/watch?v=j6jUK31udZQ
Cheers,
Guy
I have decided I will be doing the bike Japanese Bratstyle.I'll keep updating the thread in case anyone is interested...
Progress is slow but the teardown is pretty much complete and the frame is cleaned up. Coming up, I will remove some tabs from the frame. Then will be stripping the old paint and rust, and ~6 coats of epoxy appliance black. The swingarm has received copper bushings and a fresh coat of paint.
The tank was trash as you can see in the first few pics. I tried a few experiements. I filled sanded iit and sprayed it with rocker panel rubber, then painted it flat black. It's better, but not as good as I want it.
Next order from Mikes XS is 11" shocks, steering head bearings and a few more goodies. Pics coming tonight
