Starter and starter magnetic switch removal
evilaugust
I'm wanting to shed some pounds on my CB350F and don't use the electric start, plus I'm planning on using a smaller battery that might not get the job done anyway. Are there any issues with removing the starter and magnetic switch from the electrical system that I wouldn't be getting from the wiring diagram? Mechanically with pulling the starter? I've had it out before. Can I just put the cover back on and go after sorting the wiring out?
I don't know that motor as well as I'd like to, but there are a few things.
If that starter clutch system uses an idler gear and/or chain, you should remove them at the same time to pull the starter.
You need to plug the hole it leaves as well.
As for eliminating the starter solenoid and such from the wiring it should be straight forward.
If you think you might sell the bike one day, I'd leave the button in place and the wiring in the harness in case the next owner wants to put it back.
By single gear to you mean direct from starter to flywheel, or is it starter to intermediary gear to crank?
If the first, then yes, you can probably pull it.
If the second, you should probably pull the intermediary as well.
As for plug, a lot of people fabricate an aluminum disc with a groove for an o-ring to seal the cases where the starter motor used to.
You may be able to buy one for your model, as there are a few folks out there making them.
Also called "blanking plates", "starter plugs", "starter eliminators" etc.
Your google fu will be better with more varied search terms.
They look kinda like this, btw (example for CB350 twin):
I haven't made a plug for 350f yet ;D
Going to check if it will fit 550 as well.
I have a busted cases for both motors ::)
I think it's the reduction gear you see when you remove starter motor, been a very long time since I had one in pieces
You may be able to use an utomotive expansion plug, not sure if there is clearance without removing reduction gears though?
Sorry, got busy with other stuff, I'll do it this afternoon and see what I can come up with
Only problem I see is keeping plug in hole without drilling case.
Here's pics of 550, 350 is very similar (holes are the same size ;) )
The boss in the foreground (bottom left) is where starter motor bolts up.
The other bolt hole holds cases together
If you strip motor it's easy enough to drill case and fit a bolt to lock plug in place, just pulling starter, the only thing I can think of at present is to make a bracket bolted to mounting lug to keep plug pressed in?
Not the 350/360 ones.
I can make a plug to fit easy enough with an 'O' ring seal, just haven't figured out how to stop it falling out when motor gets hot.
Some sort of angle bracket with a compression spring would work and be hidden under cover
I don't really like the idea on an interference fit although it is a possibility?
If plug fell out though it would at the very least make a mess and at worst get oil on rear tyre and potentially kill you
