Starter button EXPLOSION! '78 CB750k
Kev Nemo
Honda Hacker
OK, so not really an explosion ;). I was taking the starter button out of the housing to clean the contacts and lost a piece on the garage floor. It is lost and I need a new button. Few questions:
1)The reason I pulled it apart in the first place was that my headlight wouldn't stay on unless I 'wiggled' the starter button. That eventually stopped working as a solution. My question is, with the button in pieces, shouldn't the headlight come on when the ignition is in the 'on' position? I've checked fuses/bulb/wiring.
2)OEM button or aftermarket microswitch? Which switch (voltage rating please)
yeah, the light should come on with the key in the on position. Very odd that your starter button would cause this. I wonder if you have a loose ground (green wires) inside the headlight bucket. Which piece did you loose?.
1) It's not a stock cb headlight-no green wires, only blue/white/black. I've heard that it's weird that the starter button would have anything to do with the headlight, but it obviously does, as it did the 'wiggle' thing in front of a bike mechanic and he couldn't figure it out either.
2) I lost one of the small clip-looking pieces that sit on top of the plastic button within the housing and activate the contacts.
I'm seriously about to say screw it and go kick only; still need to figure out how to get the damned headlight on though >:(
I have been looking at cb750 wiring diagrams, there should be a blue/white and black?/red (power comes from black?/red and goes to blue/white into dimmer switch), a black and orange/light orange (black is hot and orange/light orange goes to starter relay) when the switch is free the headlight has power and when it is pressed power goes to the starter relay.
I am thinking that if you put a "jumper" wire in between the black?/red and blue white your headlight should work, but use a tester and check everything first.
If you don't have any of these colors... then I looked at the wrong diagram and wasted some time ;D
The 3 wires going to the starter button are red/blk, yel/blk, and blk. I split the shrink tubing to see if there was a fray, but nothing-wires look clean
What feed-Sparky said made sense. Power normally goes via the kill switch to the headlight but when the button is pressed to start it, the power is routed to teh starter solenoid instead. The implication here is that there's a really bad contact in the starter button.
If you are really good with electrics and switches, you might be able to rebuild the switch block. I'd try that first before jumping on ebay to find a replacement switch assembly.
Ok, the BLACK provides the power, when the switch is free the power is sent to the dimmer switch via the BLACK/RED, when the button is pushed the power is routed to the starter relay via the YELLOW/BLACK.
Does the headlight come on when you run a wire from the BLACK to the BLACK/RED? If it doesn't I think there might be something else wrong down the line.
YES! Awesome-I'm not crazy! Ok, I think the button is a loss; one of the clip pieces is missing, so it looks like I'll have to run an aftermarket starter button. I was going to go kick-only, but screw it-let's go cheap and easy and get riding ;D
Nice! Glad you got it figured out, the same thing happened to me. I thought it was messed up that the headlight was routed through the start button, but when you think about it, it makes sense. It reduces the load on the battery when you use the electric start.
Thinking back, I'm pretty sure it's been messed up for awhile. I remember starting it and the light only 'dimming'
when cranking. Explains a lot of drained batteries :-\
Buy another switchblock from a wreckers in town and use the internal bit for yours, or modify one of them to fit. Its what I'm going to do after losing the headlight contact for my GSX-1100. Was in there cleaning the contacts and lost the damn thing. Bloody irritating, isn't it, when you're confuzzled by an insanely small piece of copper...
- boingk
So I kick-started my bike, warmed it up, and went around the block. Headlight is still out, but I'm considering just running a toggle in the bucket for now, and riding without the electric starter until I can find one. No responses here or on another forum. Not alot of Jap boneyards in Austin. I'm going to see what I can come up with this weekend.
