Hey everyone!
I have a 1983 Yamaha XJ550 Maxim, and my starter went bad. It was making a weird noise when I pushed the starter button, so we took it apart and discovered it was full of sludge? Not sure how that happened, but I bought a rebuild kit, replaced the brushes, put everything back together, and hooked it up to the wire, HOWEVER, I didn't put it back in the engine. I wanted to see if it would turn freely before putting everything back together.
Now at this point it might be useful to say that when I put the starter back together, I could NOT turn the shaft coming out of it by hand. Not sure if it's supposed to be that way or if I did something wrong. Anyway, I hooked it up to its wire, pushed the start button, and low and behold, nothing happens. All I get is a loud click from the starter solenoid.
From previous experience with a bad starter solenoid on my Suzuki GS750, I knew to test if the solenoid was bad by bridging the poles with a screwdriver. When I did that, nothing happened at all, not even a spark. I can't hear if the starter is wanting to turn and is stuck, or if it's not getting power at all. The battery is brand new by the way.
So, what's my problem here? Bad (or incorrectly assembled) starter, bad solenoid, or something completely different? Could it be that the starter doesn't have a ground because it's not actually in the engine? :-[
