Starter Power?!?
Herm21
Ok so I finally got the engine buttoned up and the wiring somewhat done on my 450 project, I was able to fire her up after a few cranks of the starter. Bike ran for a while and I was able to shut her down and start back up a few times, but then the starter started chugging and couldn’t turn her over again.
Thinking I had a bad starter I tried another one but am having the same issue with it, it just chugs and stops! I happen to have a second project going on so I have 2 of everything and have swapped out the relay, battery, rectifier, but it’s the same issue. I then tried it with the battery leads directly to the starters, they still won’t move! I then put each starter in a vice and cranked each one up and they both spin freely and sound ok. And I can turn the crank by hand and the kick start does turn her over, so at least I know the motor isn’t seized. I even tried using my car battery but it’s the same thing, it just will not spin the motor! I did notice that no matter which battery I use the ground wire (attached to the frame) does get extremely hot though, I mean really hot, is this normal?
At this point I’m fresh out of troubleshooting idea’s and am wondering if any of you have experienced this or have any idea what might be up with this, could I possibly have two weak starters?? Thnx Herm
Connection’s good, I even tried a heavier gauge cable to be sure. Been messing with this all day and it almost seems like either the compression is too much for the starter (but even with the plugs out it does no good), or there’s some electrical deficiency when it’s bolted in causing it to “weaken”, …again if I pull it out it spins like a champ…I’m pulling my hair out!
i know nothing about how these starters or how they go in, but it sounds like maybe they are binding on something.
Check the ground connection at the point where it connects to the engine or chassis. If your bike is freshly painted and or assembled, there may be a poor return to the battery through all these freshly detailed parts. When you applied power directly to the starter, did you ground at the starter as well?
