Starter Spin???
JohnnyEscobar
Hey guys - Having a little issue with starting the bike.
I notice that when I hit the start button, it'll start to turn the engine, but if I hold it for more than a second, suddenly it stops turning the engine, and I hear something like the starter is free-spinning (at which point I immediately let go of the button), and then it suddenly catches and stops.
I am brand new to working on bikes and have been learning over the past few months by bringing this one to life. Any idea what this could be?
Luckily, the bike starts up relatively easy, so I can still get it started and going. But this issue seems to be getting slightly worse every time, and I'm concerned that eventually, it's just not gonna turn at all and just go into free-spin.
Thoughts?
Thanks!
Johnny
Thanks for the reply. Any suggestions on where to get them? I'm looking online and the very places that have them for my DOHC, they're out of stock. I see them on BikeBandit, listed by piece, though. Do I just need springs and rollers, or do I need caps, too? Caps are pretty pricey ($14 each one)
Normally the rollers are OK - it's the ramps they move on that tend to notch and disrupt the engagement of the rollers.
You can re-shape then with a die grinder.
But you need to remove the starter clutch to see how bad / what the problem is.
always replace the springs with new and i personally only use honda ones
the aftermarket ones i have tried all fail or break early
yep caps too. Alll depends on the set up. I ahve never had the rotor mis- shape but i suppose its possible. I always replace all those little parts as soon as i experience the overspin.
