Starting a project DOHC CB750, Lookin For Some Answers.
dissent89
Last week I bought a 1980 CB750K to start as my first cafe project. Its been recently salvaged but the previous owner gave up. It runs, not very strong and seems to have a slight tap, the carbs spew out fuel and its pretty hard to shift. Where can I find a good rebuild kit for the motor? Is there any kits out there for all the seals and gaskets to get into the transmission? What about a hiring harness, is there anyone that makes something aftermarket for the DOHC or am I gunna have to try and piece mine back together, it looks like there has been some shotty electrical work. One last question, what do you guys do with the fuse box when you replace the instrument cluster? Thanks for the help.
Mine ('79) is a fairly low mileage and nice running bike, so I didn't have to get into the engine. Wiring harness looks great as well. All my case cover gaskets came from fleabay. Also, I kept my fuse box in the stock location. I think it looks kinda cool.
Hey man, congrats on the purchase. I received my wiring harness in the mail the other day and will be building the new electrical system off it. Hopefully I can post some pictures as I'm as in the dark about the fuses as you. Intentional pun. However, I do have some interesting wiring diagrams that I ripped off a website around here. May not help at all.
These aren't my images or property. :)
The tap could be camchain, clutch basket quite a common source of noise on these especially if the idle is too low below 1100rpm. Pull the clutch in if stops its the clutch basket. If not the camchain is quite easy to adjust one on the front between cylinders 2 &3 and one same position at the back.
If it been stood a while you will need to strip and clean out the carbs, most likely a stuck or gummed float valve causing the fuel leaks and gummed up jets for the lack of performance. If the fuel is coming out of the black tubes on the underside of the carbs make sure the PO hasn't left the drain screws undone.
Gearboxes are generally pretty bullet proof on these so I'd check the linkages and chain tension and see it it improves. Athena doe a full gasket set over here in the UK its close on £90 so probably $140.
Not sure if full wiring harness are still available but if they are they will be pricey. I presume its been hacked about behind the left side cover thats the usual place where the starter solenoid wires are. Cant you just splice in new wires and connector and while your there replace the the solenoid with a more modern one with a 30amp fuse. Unless you plan on a complete rewire then your stuck with stock location of the fuse box, unless you want to put it somewhere inaccessible like under the front of the tank or headlamp shell.
Looks like your seat is from a F model as they are shorter than the K's also the rear lights dont look standard. But if your gonna cafe it, it shouldn't be a problem for you.
