starting my build
laurel
HPartsys!
This is my first post and also my first build.
Bought an 83 gs450l this summer cause I needed a vehicle and I used it as an excuse to buy a bike!
Making to work on this piece of shit was an adventure! I love my bike but she needs work.
Without going into all the makeshift repairs that kept me limping through the summer, I'm Reddy to restore her and cafe her out.
Step one : I think she needs a clutch.
Online I found several different parts in the clutch assy. Do i just need a whole clutch kit? I'm clueless.
You'll fit in well here. :)
What's wrong with your clutch? May we safely assume that you've done a clutch adjustment at the case and at the handlebar lever?
^+1 Whats the clutch doing and have you adjusted it?
Fk yeah...3 more GS members in two days and all three are 450L bikes. I am not the only one working on an L anymore.. whooo hoooooo 8)
GK
Hmmm... Thanks guys. I did not adjust it. I only tried adjusting it at the handlebars.
I guess I should start by cleaning the carbs and save the clutch for when it's warm enough for a test ride.
I also want to rejet the carbs so I can install pod filters.
Any advice for overhauling my carburetors?
Don't bother with pod filters unless you plan on doing a full on custom build. The stock airbox will always function better. Just spend the money on a good K&N high flow filter element.
As far as the clutch, why do you think it needs one? Specifically, what is it doing/not doing?
Walk before you run. If you're going to 'cafe out the bike' then it's a good idea to get it running in tip top shape first - especially since, no offense intended, it's clear that this is new territory for you.
It's a good time of year to give the bike a once-over, and learn about how each piece interacts with the next. If you're not familiar with cleaning the carburetors, then jumping to pod filters (which as Von says above will be difficult to get working anywhere near as well as the stock airbox) is a step down the road.
If you're not a member at GS Resources yet, it's a great place for the GS series of bikes, with some really detailed walkthroughs and a knowledgable userbase.
As far as advice goes - take a thousand pictures of everything as you take things apart - it's free, and can make the difference between a good running machine later and a hastily-written craigslist ad down the line.
You are correct that this is new territory for me. I'm not scared though. I want a totally custom bike. Pod filters are part of the look. Has to happen. The carbs need cleaned anyway. Doesn't it make sense to install new jets while I'm in there?
Ass far as the clutch: when I first let go the bike hesitates, then it catches and takes off.
Ink check out gs resources. Thanks for the tip. I figured I'd ask you guys since removing the air box is a cafe standard so to have probably done it.
Nope - because you won't want to make any jetting changes until you have the whole fuel and exhaust system done. Carb tuning is a difficult process; if you search the how-to sections here, I think that Sonreir or crazypj have put up some great technical articles and videos on 'why a carburetor works'. It isn't going to be as straightforward, necessarily, as saying "here are the pods I bought; which jets do I use?"
There's a tutorial on GS Resources that will walk you through a clutch adjustment.
Best luck!
Hmmm... This is going to be challenging.
So you say I should start by picking out my new exhaust, the tune the girl before I make any changes?
Go buy a set of calipers. Measure your clutch plates and springs. Probobly just worn. The specs will be in your manual (if you don't have one, get one).
As far as the pods...
If you're doing a full on cafe build, there's a lot to do other than sticking some pods on there. What's your plan? Have you torn the bike down yet?
And yes... The carbs, motor and exhaust all work together as a system. Can't change one part without changing another.
You should do absolutely everything else before making any changes to the fuel system. Exhaust, valves, any engine work you plan (or discover is necessary) to do. Mostly you should read up on what you're getting yourself into, and crack jokes at other forum members' expense.
Now start a build thread and get that saw out.
If anyone knows about a Clutch, it's this old world samurai. :) Adjust it at the case before you take it apart.
AApartht, thanks guys.
My foot is in the door Now. This is going to cost an arm and a leg, huh?
Great that it's winter. Plenty of free time. Fewer paychecks though, too.
Alright, I'll go tear some shit apart and take some pics.
Laurel,
Rich and Mike are right. Get the bike Up and running correctly first. Then do your changes in Air/Fuel/Exhaust work. It will make the final tuning much less painful.
As far as the the GS Resources goes it's a winner when it comes to the mechanics. Look up the BIKECLIFF site through there. It is a seperate site that has pdf manuals on almost every bike as well as tip/tricks/and info.
My bike did the same thing. Partially was stuck plates, partially was an old worn cable. After I got the engine warmed up and running the heated oil broke the plates loose. The problems with the lever pull and engagement were worked out with a good cleaning of the lever housing and a new clutch cable.
Start with the easier most probable solutions and work your way up. Don't just tear into the clutch if you don't have to. And like stated before get the manual and take lots of pics etc as you go if you have to get into something more in depth. Going the slow and steady route, reading, and asking questions, will keep you from spending an arm and a leg when it isn't always required.
GK
Thanks.
If it ain't broke don't fix it, right?
So, I'm going to start by cleaning the carbs. Sound safe?
Where do I find rebuild kits?
Also I already have new fork seals. Guess I should install those. That should keep me busy for awhile.
Before you start, go buy an impact screwdriver - five bucks at Harbor Freight, twenty at NAPA. It looks like a screwdriver that you hit with a hammer, and it will keep you from stripping the screw heads as you disassemble stuff that hasn't been opened for 20+ years.
I like z1enterprises for parts; bikebandit and boats.net is pretty good too. Z1 sends more stickers though. :)
