well the original steering bearing will have a "cup" in side the upper neck and a "cup" inside the lower neck that holds the bearings in place and the spine will have the same upper and lower neck to hold & support the bearings in place...
You'll have to remove all 4 pieces.
using a long rod/screw driver/whatever, you insert down into the neck and tap it out with a hammer to remove the lower cup. just do the opposide going upwards to remove the upper cup.
To remove the races/cups from the neck off the lower bottom tripple, you may have to pry it out.. this may take the most time. the races from the upper neck you just tap it out with the hammer...
you can use a ball joint remover on the race on the triple trees... or bicycle shops might have a remover big enough to do the trick.
as for the races in the frame... if they are anything like mine, get some THICK steel rod, and hit each side of the race HARD until they pop out. go around the race; too much on one side simply gets it stuck worse.
Some kits have a spacer to put in under the bearing on the stem. If your kit has one, you will need to take some measurements and work out if it is needed before you press the bearing on (because you may not be able to get the bearing back off without destroying it)
And you need a sleeve of tubing to drift the bearing onto the stem (you need to contact the inner race only - don't hit the bearings themselves)
