Steering Stem problem
thearcticsea
Hey guys,
So I started rebuilding the bike tonight and I was putting the front end together. I installed new bearings and all that and it seemed to go good.
When I put on the top triple tree it seems like the stearing stem isn't sticking up far enough. I can only thread the triple tree nut on about 3 threads, and that's without the washer that goes under it.
Any of you pros have any tips or suggestions? I'm almost sure I seated the lower bearing deep enough. The upper bearing just sits in the race, which extends a bit above the top of the steering neck, which from other pictures seems normal.
Thanks in advance.
YogiBear said:
did you cut the old races off the stem?
It's happened before lol, otherwise you have obviously not seated the new bearing race low enough on your stem, if this is the case heat it up and knock it down a little further with a piece of pipe the same diameter as the top of the race
There is no "deep enough." It's either fully seated or it is not. If the bottom outer race is not COMPLETELY seated in the frame, your steering stem will go loose when you hit a bump and the race move further into the frame.
Use a piece of PVC pipe. Put in in that bearing race, and give it a few really good whacks with a BFH. Make sure that bearing is seated.
Some aftermarket bearing sets are tapered bearing upgrades for the original loose ball bearing setups. Make sure you have all the old races removed from the frame and the steering stem.
I've been trying to beat the bottom cone race off the steering tube. So I can just cut it off? Dremel?
yep, just cut it off. Just be sure not to damage the tube at all. a dremel will work well
Have you tried heating it? If you heat the race, it expands. The stem also expands with heat, but you can usually heat the race and get it to move before the heat transfers much to the stem. I have been known to cool the stem with an ice cube after heating the race.
You can cut it with a cutting disk in a Dremel. Usually, if you can get a couple deep notches cut in it, you can get it to break.
I did something similar Alpha to mine (suggestion from Staffy). In freezer for a few hours, butane torch on bearing for a few seconds, hit it with a hammer and screwdriver, came off in 2 hits.
I got tired of fighting them, so I made a puller to get them off. I don't always intend to replace the bearings. Sometimes my purpose is to powdercoat the triple tree, so the bearings have to be removed, but not necessarily replaced. ( I ALWAYS replace the loose ball bearing type with tapered roller bearing upgrades.)
Swivel said:
Sitting parts in boiling water for a few minutes is far superior to heating hardened metal with a torch.....
The race is hardened metal that is being removed to be thrown away.
Swivel said:
Clever,I'll think I'll make one up to use in my press.....
It's a classic "bearing separator" design, but none of the commercially available ones would fit the job. This particular steering stem, (from a Sportster,) had a raised area of the tree that was in the way. The underside of the bearing separator was cut away on one side to give it clearance.
It was pretty easy to make. I just clamped two pieces of 3/8" thick cold-rolled steel bar in the vice, and round out a dish with an angle grinder to get the basic shape.
Swivel said:
I thought he was putting a race on,....time to sit on the naughty step..... :'(
You've been schooled by the neevo Swivel ;)
edit: [/gloating from Swivel not reading it properly]
