Stock exhaust replacement
rACEr
Hi guys,
I was thinking of getting the re-jet kit and the EGR blanking plate for my Ace 125, so should I do something to the stock exhaust or replace it?
Hi rACEr
Kind of depends on where you are as to what is available.
Take a look in the exhaust column in the link below to see what others have done
https://docs.google.com/spreadsheet/ccc?key=0Al1LNMJQkZqydE1YZHVpV2RoOGJQVmpkT1ZKMVozSlE#gid=0
I have added a row for your at the bottom, and welcome to the gang.
Welcome aboard!
Removing the CAT in the header, by whatever means you can, is the most important change you can make!
Re-jetting without getting rid of the CAT will make little difference. Whatever way you go, try not to reduce the length of the system as this has a deleterious affect on mid range power.
Crazy
... Hi Racer, without a doubt, replacing the stock exhaust with 00Racing's kit was the single most transformational thing I've done to my stock Ace, gave it a completely new 'soul' ... highly recommended.
Haz
