strange cb360 wheel issue
sbaugz
DTT BOTM winner
So I ran into some sort of strange issue with my CB360 wheel. Its the rear wheel.
I took it all apart, including removing bearing retainer, bearings, drum, tire, etc. Its basically just a rim, spokes and hub at this point. When I move the wheel around, I swear I can hear water sloshing around in there. I don't see anything dripping out , nor do I see anything wet. I can't figure out where the hell there would be water though. Am i hearing things? Any thoughts?
Check the lips on the wheel. Sometimes the lip (that the tires bead rests on) gets dirt and water inside them.
Ok will check that out.
How do I get the water out if that is where it is ?
Are the bearings installed on the hub? If not, throw the whole thing in the oven for 15 minutes. Or just wait a couple days for it to evaporate.
BeArings are out. Only thing left in wheels are the four rubber bushings for sprocket.
What I dOnt understand is how water can still be in there. The wheel has been sitting in my dry basement for 4 months now.
I suppose once I get them powder cOated, it will evaporate anyways?
It might not be water at all - I've had sand in some wheels before from sand blasting them.
Can you get the cush drive rubbers out and bake the wheel? Just so you KNOW it's not water.
I'd love to get those rubber bushings out but from what I hear that's next to impossible to do
Take a look at the inside edge of rim where tyre bead seats.
There is usually a small hole to allow gas out when they are welded.
'Stuff' gets in there and rattles or sloshes around.
Holes may well be blocked with rust so water can't get out
I've never been able to re-use the drive pin bushings after removing them.
I have heard of people drilling a 1/8" hole from inside brake drum then heating hub and punching out but I haven't tried it
I would absolutely paint the rear hub. Powder any and everything else, but paint the hub. Getting those bushings out is a bitch. And they're not cheap to replace. I did mine and regret it. Appliance epoxy paint at lowes is good stuff. Comes in rattle and a quart.
