Structural Integrigty?
3cermak
I picked up a cheap barn find this past weekend for a winter chop job and one area on the frame concerns me.
It is in the batt. box area on the flat part of the tubing. Not sure how much you can tell from a picture but tubing itself looks intact with no distortion. The corrosion seems to be only skin deep.
I'm sure many of you have seen some pretty gnarly bikes so I'm seeking opinions as to whether this thing will ever safely ride again. What i'm not sure about is stress points on a frame and if this area is a concern. If it is can it be reinforced?
Once i get some decent light I will take some pictures to properly introduce the project.
Cheers,
First off, welcome to the site! If the tubing itself (I'm sure you mean the frame) is looking pretty good, I couldn't imagine how a little bit of rust would make it unsafe. What are the mounts for surrounding it? Seat pan? Maybe get those other pics up sooner rather than later. Got any welding skills? Than everything can be reinforced.
My concern is not so much the rust as it is the bent portions most visible in the second photo. It is the flat area where the battery box normally fastens to but looks like someone shoved it through the frame as opposed to unbolting and removing it from the top.
Thanks for the response.
looks like its been cut out to fit oversize battery?
What bike is it? CB175/200?
No big deal, its normal to plate open part of 'C' section frame and turn it into box section for extra strength.
Just bend pieces back into shape and plate over them, its only mild steel.
PJ
If you can weld " it's just like sticking shit to the bed sheets with a putty knife"....it can be repaired
;D ;D
dats funny
PJ
