Stuck CB360 engine
ADGpunk
A couple of weeks ago I acquired a 75 CB360 that has a seized engine. Since then I've been spraying the PB Blaster into the cylinders every day, but haven't had any luck in freeing up anything. I've removed the cylinder head cover to begin breaking down the engine and got stopped at removing the cam chain. I can remove one of the bolts that holds the cam sprocket in place, but the other is inaccessible. I've also pulled out the cam chain tensioners, but can't get enough slack in the chain to wiggle it off the sprocket.
Is there anything else that I can do to get more slack into the cam chain? Also, at what point do I give up keeping the cam chain intact and go ahead and cut it?
Thanks,
Ben
Thanks for the suggestion. I'll give that a try sometime soon.
I've tried to turn the motor at the generator, but all that I've been successful in doing is unscrewing the 14mm bolt, or tightening it to the point that I think I might break it.
-Ben
-Ben
Pour some coca cola into the cylinders.
