crazypj
Split personality, I fake being smart
Oskimo said:Sure do. Thanks for checking on that for me. Went to the salvage yard and pulled one straight out of a 360. Put it all together, and sure enough that extra 8mm made all the difference. Clutch plates are free and we're ready to ride!
Only thing is, the clutch lever seems a bit stiff. I don't think its the cable as its fresh and routed correctly. Think it'll loosen up when I get the thing running or should I go back to stock springs? Don't need a cable snapping on me while im breaking her in.
Just make sure it's lubed up. I would disconnect cable at bar end, tie polythene bag over it (make hole in one corner so inner wire is free) and let engine oil soak in overnight
If you get oil puddle underneath, you know it worked ;D
