Stupid Question? Differing oil filter housing bolts on CB550s and CB750s
carnivorous chicken
Over 1,000 Posts
Maybe a dumb question but... I'm switching out an oil filter housing bolt on a CB550 -- the one that's on there has the head stripped. I have two donor bolts -- one from a 1976 CB750K and one from a 1978 CB550K. The bolts are the same part numbers -- 300-020 -- but they're different: the one from the 550 has a larger size head (makes sense, the smaller ones strip easily), but it's also got a smaller diameter internal oil passage, and more but smaller holes in the bolt for oil flow. The 750 bolt has a larger diameter oil passage and fewer but larger passage holes. Again -- they show the same part #s. Did Honda replace them? Any difference?
Interesting that the orfice size is different. Honda had lots of complaints about the small bolt size and the bigger head really makes maintence a lot easier. I know he 77/78 CB750F has a longer bolt to accommodate the sandwich plate between the oil filter housing and the engine case.
