Surface rust on Chrome
mothgils
Coast to Coast
I have a Kerker 4-1 for my CB550 that is chrome and has surface rust. Is there a way to remove it while still saving the chrome? One way I was thinking of going was to sandblast it and paint it, then use header wrap, and flat black the muffler.
any help would be great!
Depending on how bad it is, you may be able to rub the rust out with steel wool.
Is it really just surface rust? Can you just buff it out or is the chrome really pitted and just general destroyed?
I took a wire wheel to it and removed most of the rust. How will I tell if it is pitted? Will sandblasting remove the chrome and rust or does it have to be chemically removed?
I had some luck last night using aluminum foil, coke, and WD40 on the rust and then following it up with Nevr Dull. It still looks like it has pitting. I might just check into having it stripped and re-chromed.
Would the chrome need to be removed before being painted with exhaust paint?
You would have to sand or rough up the chrome a lot before the paint would really stick well to the chrome
