Suzuki 125 twin, need of electrical help!
locopuffs
Everything is relative.
Hi, i have a Suki 125 x-4 that im building caféracer style and i decided to go 100 % racing with it,
so i don't need any lights or any other bullcrap. My problem is that i have no idea how to get ignition working since its the first bike i've ever touched electrics on.
I Have all the cables and stuff but it was separated from the bike when i got it.
So, i have no idea how or where anything goes, im hoping one of you guys out there could give me some much needed theoretical help.
Peace and love.
If you're going full race spec on it, you'll only really need to connect the output from the magneto (generator) to the input for the coil. Kick or pushstart and away you go! I've done that on my little Kawasaki 100 and it works quite well.
For a kill-switch, use the handlebar one. The centre terminal should be connected to ground (handlebar) and the 'kill' position should be connected to a wire that connects to the one that runs from the magneto to the coil. When you flip it to 'kill' the current from the magneto bypasses the coil and runs stright to ground, shorting the ignition circuit and cutting the engine. You WILL require this for racing.
Cheers - boingk
Thanks a lot Boingk!
Suddenly i feel a lot more certain that my project will work out.
If you could post a pic of it, or a wiring diagram or a pic on anything like it, it would be worth gold to me!
Peace and love
Question..does this bike run a magneto or is it an alternator or both?The latter will have a rectifer,voltage regulator....and a battery.If its an alternator only, you can substitute the battery for a capacitor,,and maintain the stock( charging )system.....or use a total loss system,gut all electrics including your crank mounted alternator(optional)a couple of freshly charged batteries handy,,,90% of vintage road racers are total loss,,,,because aftermarket magneto's are too farking expensive ;D
Argh, I'm from Sweden so I'm having a hard time relearning all the technical terms in English, so sorry can't answer your question :( Will try to take some pics of it.
But is it possible to just pull the wires straight from the crank-mounted magneto (???) through a on/off switch and then to the ignition condensers? What is needed to make it work?
Why can't aftermarket magnetos be less expensive, could have saved me this PITA...
What year is it?
I've only worked on X-5 and X-7,they had electronic ignition.
PJ
It's from 81.
If it is possible to wire the ignition straight from the magneto to the condensers, how the heck do i match the wires right?
Cus out from the magneto the following wires come: Green, green /w white stripe, blue, black, white, yellow /w green stripe and red /w green stripe.
And in to the conds only four wires are attached black,white and 2 orange ones...
The black and white are probably the ones coming straight from the magneto but the 2 orange ones... where the heck do they come from??
Tried to follow the wires through the old system but it's just to beat up :(
This really sucks, getting tank and seat finished up now and the only thing missing is spark!
