Suzuki brake questions.
Big R
Heaven is so far away.
Let me start by saying I'm pretty clueless about brakes. But I'm looking for a master cylinder for my dual disc setup. The front end is from a GS650 and I hate the original square mc. I don't know where the piston size is or if the piston or resivour needs to be a different size. Any and all input is appreciated.
The piston size on the Hondas is cast into the cylinder underneath. something like 5/8 or 14mm depending on model. You could always measure it if you pull it apart. It's really only the diameter that matters in this application. Radials are more sensitive to travel as well. There is a chart somewhere. I'll have a look for it.
cheers
ian
Thanks Ian. If you do find a chart somewhere, let me know.
Anybody know of any problems with using a mc from a bike with only 1 caliper?
still lookin'. Did find this:
The bigger the bore, less stroke but more force will be required to reach a given pressure. The smaller the bore, more stroke but less force will be required to reach that same given pressure.
but it doesn't take in to consideration different caliper piston configurations.
As far as single-caliper unit goes - it will work, but it's a bit of a gamble as to how much feel and power you'll have. If you have one, give it a go. What have you got to loose except a bit of brake-fluid ;)
cheers
ian
What year is your GS650? Because early GSes did not use a square master cylinder. They have a round plastic bowl on them. My 78 GS750 with dual disks has the factory master which is 14mm bore. Hope that helps.
not a good idea. The master is normally a smaller bore for single caliper bikes. Which means less fluid flow for you dual calipers. I recall reading some where that Suzuki single caliper MCs are 12mm
here is a good picture of my master.
Thanks man. I guess i do have a lot more research to do.
I don't remember what year the front end is from, but they are gs650 forks, calipers, and rotors.
I have a round mc from an 80 gs450 and a square mc from an 83 gr650- both single caliper front ends.
Within reason the reservoir size doesn't matter. Same applies to the shape. What matters is the diameter of the piston in the M/C in relation to the piston size and number in the calipers. Michael(mercury) Morse at Vintagebrakes.com has a handy dandy chart and explanation of what works and what doesn't. You may have to slip a caliper off to measure the piston size if you don't already know it.
Hmmm. His site is down. Hopefully it's only temporary.
Right now everything is apart for rebuild/ paint/ cleaning so I'm in no rush. Besides, I have to get the bike to go before I need it to stop! Thanks Teazer.
Is this your project GS or your nice one? Uh, that is to say your project or your original one? :D
Have you had a chance to see of the side cover worked out?
That's the problem with having 3 of the same bike : they all kind of blur together! But no, this is for the "cafe" bike.
I've been working since we talked last, but I still plan on taking pics of it.
