swapping out guages
brewtown16
what, me worry?
taking all of the clunky cb gauges and putting in a clean 1.9" from mikesxs.com. they have some speedos that are cable operated (i prefer) and electronic. does anyone know if the cable operated ones will work on my cb360? or will i have to go with the electronic one? or if anyone has any other affordable suggestions i would be happy to hear them. thanks, brew
Part #03-0751
http://www.mikesxs.net/mikesxs-accessories.php?category_id=8.5
From what info I could find when I was looking to do the same swap on my kz650, MOST of the 70's jap bikes used the same speedo and tach ratios. I'm not sure what the speedo ratio is on the gauges from mikes, but the tach ratio is 5:1, which is the same as the stock kz gauges. Hope that helps at least a little, I know I got kinda frustrated when I was going through it all and no one had answers for me either.
I am not sure if it will work on your cb360, but I used the "Speedometer - Chrome Mini - 2.25" from Mikessx.net to swap out the speedo on my '04 triumph Bonneville, and it works.
If you want to find out more about the mini speedometers and tachometers, there is a ton of good info in the forums of triumphrat.net
This info is from an old thread on that site.
A member emailed Mike and asked if the 2.25" speedometers have a 2:1 ratio or a 2240:60 ratio.
The response from Mike was: "All Japanese Speedos are 2240rpm= 60mph"
I am not sure what that means exactly, but I thought it might be helpful.
Good luck
Good luck
from what i know, 60:2240 is mainly for large wheel bikes, like your 21" harleys. from what i can track down is that most of your japanese bikes are 2:1, with a pretty universal style threading for the cable. i looked around on that triumph site and didnt come up with much. nither did my Clymer manual on the subject. i even went as far as to call my local honda dealer who supposedly "restores" old bikes and the woman behind the counter just heaved bullshit at me. so i think this is going to take a little more digging than i thought.
