Hello all ;D
So a few weeks ago I rode my '78 KZ650 to the Toronto Spring Motorcycle show, having just drilled my main jets out to 1.17mm I started to open her up. When I approached the 145, 150 speed range I got this nasty speed wobble and had to back off!!! ???
Well today I removed the rear wheel and shocks and noticed that there's about 1/8" play side to side!
I removed the swing arm and the needle bearings and inner shaft look great. What I did notice is that the inner shaft protrudes past the needle bearings by about 1/8", this can't be right ?? The manual only calls for the dust washer/caps to be installed, and with the swing arm pivot bolt torqued to spec the play is still there. The frame contacts the washer/dust cap which in turn contacts the inner shaft, is it possible that shims are called for and missing?? This sounds like the fix , but for the life of me I can't understand why no mention in the manual????
Thanks in advance !
Thanks in advance !
