gomotomoto
The previous owner of my bike set up a simple toggle switch that turns the front lamp on. It also has a + positive lead that went to the condenser wires (see pic #5) I assume that the switched power was set up to #5 before each + lead that went to the coils. When the switch was off, the bike would not spark. I figured, the previous owner set this on/off switch up so people couldn't just kickstart the bike. though I've always felt that locks are for honest people. If someone wanted to steal the bike, a switch probably wouldn't deter them. Anyway...
I've changed the ignition from the original points to a pamco electronic ignition, so there's no more condenser in the equation. I guess it'd be easy enough to set the switch back up, but I'm not 100% sure that's what was going on with the wiring (#5 was set up to break the circuit to each + on the coils)
So two questions:
- do you think it's worth it to set the switch back up to kill the ignition?
- if I'm going to set this back up, do I interrupt the + on each coil with the same setup that was there with the coils?
Thanks for the help, getting close to rolling this thing off the table and sparking it up!
So two questions:
