neevo
Over 1,000 Posts
I am a stickler for quality so I want to make sure the plan I have for the bars is going to work and look good. I have ditched the stock levers, perches and switches as they are a bit too far gone and getting them where I want them is going to be too hard. So the plan is to get some aftermarket levers and replace the switches with modern equivilents.
I had a look on Dime City and found a Nissin master cylinder in black for the front brake that looks ok. Anyone have any experience with these? The perch for the clutch is dirt cheap, are these high enough quality? I want the best I can get for approx $200 (for both).
Also going to be running a couple of these... mainly because they are the coolest thing I have ever seen!!!!
So the plan is to make a bracket so I can recess the ignition barrel approx an inch and create a mounting point for each button each side of the ignition for the bike running switch and starter button. eg:
Now I assume this means I need the following switch blocks:
Left:
1. Hi/Low Beam
2. Indicators
3. Horn
Right:
1. Lights On/Off
Does that sound right? Are the switch blocks on Dime City enough for this? I know they have a lightingswitch block but not sure if its for Hi/Low too. Don't mind mucking about with wiring just want good quality blocks that have the functions above across both of them. Would also prefer 2 so that it looks better by balancing up the bars a bit more than just having the 1.
Cheers in advance DTT legends.
Left:
1. Hi/Low Beam
2. Indicators
3. Horn
Right:
1. Lights On/Off
