Synching carbs with a homemade manometer
Useful Idiot
75 cb500t. I make a manometer using clear tube, trans fluid and a yard stick.
Here's the steps I took:
Timed the bike perfectly.
I loosened the trottle cables completely.
Backed out the idle screws completely.
Hooked up the manometer.
The problem is, my left carb keeps trying to suck the fuild into the carb, no matter how I adjust either carb. I'll screw IN the idle screw on the left carb (thus decreasing vacuum) but it still has way more vac. than the other side. I have to keep killing the bike before it sucks the tranny fluid in.
I'm wondering if I can just buy a couple of low pressure vacuum gauges and mount them to a board or something, instead of using fluid? That way i could leave the bike running and be able to play with the adjustments til I get it right.
Any ideas?
I've too made my own meter with the same tools as you and had good results. Make sure you've got good connections from the tubes to the carbs, then turn down the carb that has the higher vacuum and up the other one. It actually doesnt take much tweaking to make a big difference and that might be your issue. Just keep trying to calm the one so it doesnt, well, suck so fast. Turn it down, start the engine, turn it down and so forth.
Here's a suggestion which might work for you; this is off the top of my head, so bear with me. I don't have a way to test this method right now, so if you choose to try it, I ask that you let us know your results in this thread, so we can all learn from your work.
Go to a pet supply store that carries aquarium supplies, and get a couple of air valves; you'll need two, one for each cylinder on your CB500T. I'm thinking of valves that look something like the ones in this photo:
http://www.aquariumguys.com/twowayvalve.html
You want to insert the valves so that you can easily reach them while you're adjusting the carbs; a little trial-and-error should help you decide where to put them. You want them AWAY from the trans fluid, so no fluid will get sucked into them. You DON'T want the trans fluid flowing through the valves, so make sure you insert them into the tubing up near the carbs, as far away from the level of the trans fluid as reasonably possible. The valves will be used to adjust the AIR flow in the tubing ABOVE the level of the trans fluid, so keep that in mind when you decide where to cut the tubing. Again, you do NOT want any trans fluid sucked through the air valves; you want the valves to regulate the AIR FLOW through the tubing, WITHOUT getting the trans fluid into the air valves themselves.
Once you've decided where to install the air valves to make them easy to access while you're synching the carbs, cut the tubing, and insert an air valve into each line. Make sure the connections are tight (no air leaks at the joints), and you should be ready to work.
Don't forget to sync the carbs ONLY when the engine is warmed to operating temperature; you can't sync them if the engine is cool or cold. Not trying to insult you or anyone else; I'm just reminding you of this because I realize you might be in a rush to get the job done, and that could make you forget to warm up the engine properly beforehand...
When you start the (warm) engine, adjust the knobs on each air valve to prevent the engine vacuum from sucking the trans fluid into the engine... again, some trial-and-error will come in handy here. The air valves will let you control the amount of engine vacuum in the tubing, and that will keep the trans fluid out of the engine.
This probably seems a LOT more complicated than it really is, but since I'm brainstorming this as I type, I can only hope that you can make some sense of this. I don't have any of these materials on hand, so I can't tell you how well this will work; you might have to modify my instructions to get suitable results.
Obviously, the idea here is to use the air valves as dampers; the adjustable knobs on the valves will allow you to regulate the engine suction enough to prevent the trans fluid from being sucked into the engine while it is running. Once you've got the trans fluid under control, you should be able to sync the carbs. Don't forget to take a test ride when you're done, to be sure you're happy with the results of your work... OK, so maybe that is just another way to ensure that you take time to ride when you're done working, so you can see if everything is working the way you expect it to...
Just for the record, I've never owned an aquarium; I got this idea only because I was looking at an aquarium today while my girlfriend dropped her car off at a local repair shop. The shop owner seems to like tropical fish; I looked at the tubing running through the aquarium, asked him some basic questions, and learned a bit about air control valves. When I got home, I re-read this thread, then realized that the aquarium control valves might just do the trick for your manometer.
Good luck with this; let us know if you have any questions. If you try this method, let us know how things turn out, and of course, feel free to post some photos, so we can see your manometer in action.
-- kd
