Tail light funkyness on 72 cl350
rock2d2
Born to lose, destined to fail.
So my tail light is functional in the basic sense of the word. On depress of the rear brake it lights right up. Clean smooth bright, no problem. When I depress the front brake lever the light doesn't come on until I'm ALL the way in the brake. As the majority of real stopping is done with the front brake this could be an issue.
I've ordered new perches and levers for brake and clutch, new tail light, and all new cables, (none of these were ordered to fix this, all aesthetic, but it can't hurt to ask if something I was already going to do will fix a problem I'm already having.....i think?)
Are any of these going to remedy this or am I going to have to break out the wiring diagram and act like I can decipher the differences between it and Egyptian hyroglyphics?
If you're changing perches, and the new perches will have a new switch in it, it'll likely cure your problem.
It sounds like the switch just needs adjusting ;)
Wait, I just realized. I have no clue how to adjust the switch.
How does one adjust the switch?
I'm not familiar with that bike specifically. There are plenty of other on here who are though ;)
If nobody else chimes in sooner, take a pic of the lever and switch and I could probably figure it out for ya :)
I did some reasearch and found the answers. Sounds like the new perch SHOULD have the switch in it, but we'll see upon delivery.
