Taillight
interceptor
Coast to Coast
There was a thread not to long ago about installing a resistor in your tail light wiring to use your rear light as a tail light and a brake light. I bench tested my setup and it works great (using a LED trailer light that has it's own built in circuit board.). My question is about the resistor. I found one at work that has the colors: Yellow, violet, red, gold. I found the color chart for resistors and if I did my math right it means that this resistor is 4700 ohms or 4.7Kohms with a 5% tolerance accuracy. Does it sound like this resistor is ok to use? Does it matter which way I install the resistor, is it directional? And how should I deal with the heat from the resistor, leave it exposed?
Thanks in advance for your help.
