woody1981 said:What kind of oil? Motor oil? 3-in-1 oil? Fork oil? WD-40 oil? Baby oil?![]()
DrJ said:Some swear by the old tin foil and cola trick.
HerrDeacon said:Hey DrJ, care to elaborate a bit on this? What do you exactly do with those two? Do you put cola on the rust and then rub with the foil?
tobiism said:Just put some coke in a bowl, ball up some foil, get it wet with coke, and scrub lightly. I just did this to the Katana forks the other day.
spankey said:PB blaster is a penetrating lube similar to WD-40 but alot better. I usually use it to loosen rusty bolts that I need to save. You can usually get it at most auto parts stores.
TonUpSoldier said:NOT similar to WD40...WD40 is not a penetrant. People oft think it is, and if used as one its crap. Its best useage is for water repellant. on contacts and what not. PB Blaster is THE SINGLE best penetrant i have ever used. Its helped break loose nuts and bolts that i was sure i was going to have to cut off.
